Hi Survey123 team!
I am building a survey/questionnaire and am attempting to insert a background image, one we have used for other team surveys (created by Louise Branscomb ), but when I use the same public url she has used, I get a file size error.
Error:
the image file ( which is only 175kb):
Survey link:
https://survey123.arcgis.com/surveys/d21a9f70f5da480b9f15e61d8a6004dc/design
Can you help me understand what I might be doing incorrectly or why this file isn't working for me?
Thanks!
Hi Michelle,
What browser are you using? Have you tired to clear your browser cache and history, and/or try using a different browser? Or you can try private/incognito mode.
For the other people on your team it is working for are they using a different browser and was it working before for them, or just now?
Phil.
Hi Michelle,
I believe this issue will be fixed for the 3.3 release which should be available next week. Please try again then.
Phil.
Thanks, Philip! I will try again next week.
Hi Phil, I just re-tried and am still getting the same error. Other people on my team can access and add this image to their surveys (the image is public and doesn't exceed the file limit), not sure why it isn't working for either of my surveys. Thanks
Hi Michelle,
Phil.
Hi Philip, I will try another browser to see if that makes a difference. But in the meantime, I saved the image elsewhere (outside of ArcGIS, but publicly accessible) and it loaded fine. So It might be something with my permissions and where the original image is saved.
