Why do the group heading and background colour are not changing?
1401
6
08-09-2022 09:07 PM
MaCharmaineMiciano
Can please someone help me? I want to change the heading of the group from INCOMPLETE to COMPLETE once all the questions have been answered and change the background colour into light Green. I tried these expressions from the other forms that I created and they all worked fine except for this one. I uploaded a sample questions in my form.
Thank you for any help.
Charmaine
DougBrowning
MVP Esteemed Contributor
See attached.  It works fine.  You are not creating your if statements correctly.
Also there is no need for 3 different comment fields.  The schema will be horrible to use.
I also removed the font color since if you have the background and the text the same color you cannot see it. See below
The attached is much simpler and works.  Hope that helps
DougBrowning
Your if statement has several issues.  I am not even sure what you are trying to do here so I cannot fix it.
it must always be if(condition, true, false).  You have several if statements just sitting next to each other.
if(string-length(${runoffcontrol})=0,
      0, (true)
       if(string-length(${runoffcontrol})='yes', (false)
             'no', (true)
             'notapplicable', (false - this is where it goes wrong)
             1, (??)
                 if(string-length(${comment4})>0,1,0, (you have a true and false here)
                if(string-length(${comment5})>0,1,0, (you have a true and false here)
                if(string-length(${comment6})>0,1,0))))) (you have a true and false here)
Maybe you are trying to add them up?  If so you want if() + if + if ... etc.  But then you have a NA in there which of course you cannot add.  So not sure.
Hope that helps
MaCharmaineMiciano
Hi @DougBrowning ,
Thank you for your help. I just recently started learning how to create forms in the Survey 123.
Sorry if I didn't explain it clearly in my recent post, but what I want to do here is when all the questions have been answered a word "COMPLETE" will appear in the heading and the background color will also change into "LightGreen". However, when all the questions are not completely answered a word "INCOMPLETE" will appear instead in the heading, and the background color will also change to "LightPink".
Can you please recommend an expression to me on how I will make this happen? or its not possible because of the "notapplicable" option in the choices?
Thank you again for any help.
Regards
Charmaine
DougBrowning
There are just several logic errors with your if statement.  If you want when all are answered just use a and.
if(string-length(${runoffcontrol}) > 0 and string-length(${comment4}) > 0 and string-length(${comment5}) > 0, "LightGreen", "LightPink")
MaCharmaineMiciano
Thank you for your help @DougBrowning .
I tried the syntax above that you suggested, but it was not working. I wonder what's wrong.
DougBrowning
MaCharmaineMiciano
Thank you heaps @DougBrowning for your help. I still need to learn more.
