What layout option removes the XLSForm settings style from a group
961
04-02-2023 11:58 PM
ChristopherCounsell
MVP Frequent Contributor
You can set 'fixed-grid' or 'dynamic-grid' styles for groups on the style column in the Survey123 XLSForm settings sheet.
You can also overwrite the above by setting the esri:bind:style column to layout=dynamic-grid.
Can you set a group back to the default setting and what layout keyword would set this? e.g. group style binding is layout=default or layout=false?
ZacharySutherby
Hello @ChristopherCounsell
Setting the group appearance to w1:X where X is either 1 or the w value for that groups parent. In this scenario that group will then display like a normal vertical group.
Thank you,
Zach
ZacharySutherby
Thank you,
Zach
