what am i doing wrong with this calculation?
1313
04-21-2023 11:58 AM
EvanDarpini
Its suppose to perform the square root of the sum of squares depending on how many inputs are selected
if(selected(${DBH}, '1'), (sqrt(pow(${DBH1}, 2))),
if(selected(${DBH}, '2'), (sqrt(pow(${DBH1}, 2) + pow(${DBH2}, 2))),
if(selected(${DBH}, '3'), (sqrt(pow(${DBH1}, 2) + pow(${DBH2}, 2) + pow(${DBH3}, 2))),
if(selected(${DBH}, '4'), (sqrt(pow(${DBH1}, 2) + pow(${DBH2}, 2) + pow(${DBH3}, 2) + pow(${DBH4}, 2))),
if(selected(${DBH}, '5'), (sqrt(pow(${DBH1}, 2) + pow(${DBH2}, 2) + pow(${DBH3}, 2) + pow(${DBH4}, 2) + pow(${DBH5}, 2))),
if(selected(${DBH}, '6'), (sqrt(pow(${DBH1}, 2) + pow(${DBH2}, 2) + pow(${DBH3}, 2) + pow(${DBH4}, 2) + pow(${DBH5}, 2) + pow(${DBH6}, 2))),
if(selected(${DBH}, '7'), (sqrt(pow(${DBH1}, 2) + pow(${DBH2}, 2) + pow(${DBH3}, 2) + pow(${DBH4}, 2) + pow(${DBH5}, 2) + pow(${DBH6}, 2) + pow(${DBH7}, 2))),
if(selected(${DBH}, '8'), (sqrt(pow(${DBH1}, 2) + pow(${DBH2}, 2) + pow(${DBH3}, 2) + pow(${DBH4}, 2) + pow(${DBH5}, 2) + pow(${DBH6}, 2) + pow(${DBH7}, 2) + pow(${DBH8}, 2))),
if (selected(${DBH}, '9'), (sqrt(pow(${DBH1}, 2) + pow(${DBH2}, 2) + pow(${DBH3}, 2) + pow(${DBH4}, 2) + pow(${DBH5}, 2) + pow(${DBH6}, 2) + pow(${DBH7}, 2) + pow(${DBH8}, 2) + pow(${DBH9}, 2))),
if(selected(${DBH}, '10'), (sqrt(pow(${DBH1}, 2) + pow(${DBH2}, 2) + pow(${DBH3}, 2) + pow(${DBH4}, 2) + pow(${DBH5}, 2) + pow(${DBH6}, 2) + pow(${DBH7}, 2) + pow(${DBH8}, 2) + pow(${DBH9}, 2) + pow(${DBH10}, 2))))))))))))
IsmaelChivite
Esri Notable Contributor
Hi @EvanDarpini  I think a JavaScript function will be perfect for this. For example:
function squareRootOfSumOfSquares(nums) {
  let sumOfSquares = 0;
  let numsArray = nums.split(',');
  for (let i = 0; i < numsArray.length; i++) {
    sumOfSquares += numsArray[i] ** 2;
  const squareRoot = Math.sqrt(sumOfSquares);
  return sumOfSquares;
The function takes a comma separated list of numbers, squares them all one by one and calculates the sum. Then it returns the square root of the sum.
You can generate a comma separated list of numbers in different ways. Below is an animation showing the test I did with all of this. I created three experiences to enter the data. One using a single text question, a series of questions and a repeat. Just for fun.
 Attaching a the XLSForm illustrating the concept.  If you are not familiar with JS functions check out this blog
abureaux
MVP Frequent Contributor
If JavaScript isn't an option, a repeat would be a good alternative.
This is an example of what you seem to be using now:
This is the same idea, but in a repeat:
The repeat will work for as many instances of DBH as you need, all while taking considerably less nested IF statements (aka, none)!
