Weekday Date Calculation
3861
11-02-2018 10:56 AM
ErinGarcia
Is there a way to calculate a date that only includes weekdays, excluding weekend days?
More specifically- I have a 'days to comply' field that has the options: 5, 15, 30.
I'm using the equation now() + ${DaysToComply}*24*60*60*1000 to calculate the date, which works, but I don't want the calculation to include or date to fall on a weekend (or preferably holiday as well!).
ie: today is Friday +5 would be Weds but SHOULD be Friday
ie: today is Tuesday +5 would be Sunday but SHOULD be Tuesday
Would like something similar to the workday function from excel.
Workaround: changed calc options to include weekend days, 5=7, 15=21, 30=42
However, this does not account for holidays.
JamesTedrick
Esri Esteemed Contributor
Hi Erin,
The approach of working with calendar days is normally the correct procedure.  'Business' days/'weekend' days can vary from region to region and even business to business (as do holidays).
If needed, the day of the week can be detected via the format-date() function; using that, you can detect whether a day falls on/includes a weekend in the form and add additional days to a calculation.
Holiday detection works best with fixed holidays (such as the 4th of July); the format-date() function can be used to check the date value for a conflict.  Another alternative would be to have a list of holidays accompany the form as a CSV file and use the pulldata() function to lookup a given date.
KelliW
I am looking for something similar to the OP, but my date calculates based on a number that gets added to an origin date. So I don't just need the calculated date not to fall on a weekend, but the weekends not to be counted at all. So exactly like the =Workday function in excel. Is that possible as of now?
MichelleWilliams1
Hi Erin,
This is how we got around the holiday issue. I hope this will help someone down the road.
remember that every 5 days equals a 7 day week.
