Watermark not working as it should
428
08-28-2025 09:15 AM
ALBJORGUI
Hi everyone,
Here I am asking for help again regarding watermarks.
I attach the xls of the form I am trying to sort out.
What I have
  • An image question called nameplate_image.
  • A calculated text field nameplate_image_wm_test that contains the watermark text.
  • A debug field nameplate_image_debug which correctly contains the same watermark text (so the calculation itself seems OK).
  • I’ve tried editing bind::esri:parameters for the image question and done basic testing there, but I can’t get the watermark to show.
What I want
  • The nameplate_image image to show the watermark defined by the calculated field nameplate_image_wm_test.
What I’ve tried
  • Confirmed the calculated value via nameplate_image_debug.
  • Edited bind::esri:parameters on the nameplate_image question.
What am I missing? I have lost hope and done basic testing in the bind::esri:parameters...
Please help 🙂
Neal_t_k
Try this out,  I moved the color and size from the bind parameter field to your name calculation inside the concat().  Then set the bind::esri: parameters to: bottomRightWatermark=${nameplate_image_wm_text} and it appears to work.
Leena_Abdulqader
Hi @ALBJORGUI
Am guessing here I haven't tested it yet
For your nameplate_image row for now without any extra parameter, set: bind::esri:parameters: bottomRightWatermark=${nameplate_image_wm_text}
For your test_photo row (if you want a static test watermark), set bind::esri:parameters :
bottomRightWatermark="STATIC TEST"
Hope this helps!
Neal_t_k
Neal_t_k
You also need to add the number of digits you would like to round to in your true bearing if statement inside your "nameplate_image_wm_text" calculation
ALBJORGUI
It worked Neal!
Thank you so much! 😄
