visualize fields of my feature in my survey123
596
12-01-2018 02:20 PM
PamelaLandy
Hi , I have a problem I need to visualize a field (area) that has been entered from arcgis PRO or Collector in a field of my database to compare it with what is going to be entered in my survey ( survey 123 connect ) . How can I make this information visible in my survey ?
IsmaelChivite
Esri Notable Contributor
I think enabling the Inbox could help.
More info at Survey123 for ArcGIS: Editing Existing Data with Survey123 for ArcGIS - YouTube
And also in our help at: Prepare for editing existing survey data—Survey123 for ArcGIS | ArcGIS
You may want to enable the Inbox to allow field users to fetch already submitted data. Surveys from the Inbox will represent data in your feature layer. You will be able to open surveys from your Inbox and edit that data.
PamelaLandy
Thanks Ismael.
