I've hosted a feature service layer, which includes one spatial main layer and a relationship table. The table relationship in the main layer is a one-to-many relationship.
I configured the feature service layer and the table using survey 123 connect xls form with repeat functions. Using the service, I must validate both the primary layer and the relationship table information using the Survey 123 Mobile App.
I've enabled the inbox options on the settings tab. Everything is fine.
However, in the Inbox options, I can only search and examine the main layer features that are in formation. The relationship table information is not visible. How to examine and change existing data using inbox settings.
How to set the instance field for the relationship table's field?
Or any other options?
That is normal behaviour. If you pull something out of the related table, you can search for that value.
I found the solution need ot update the value of "allowUpdates=true query" to all the repeat group questions in the "bind::esri:parameters" colunm in xls form.
Ah. Sorry, I must have misunderstood what you were wanting to do.
Yes, using query allowUpdates=true (order shouldn't matter - this is just the order I am used to) in that column will allow you to makes edits to repeats in the Inbox.
