Validate on extra Spaces in Survey 123 connect
607
03-31-2022 04:41 AM
Kristofer
New Contributor III
Is there a way of formula to avoid the extra spaces or validation on extra spaces.
For Example
Question- Name of the Employee
Answer - Sunita   Kaushik  (Here are 3 spaces between Sunita and Kaushik)
I want to validate this. when user will answered like this (with extra spaces) Survey form will not be submitted.
Regards,
Sunita
jcarlson
MVP Esteemed Contributor
By using regex in the constraint column, you can get your survey to check for a single space.
In its simplest version, you can try ^\w+\b\s\w+$. This will match a first name and a last name, separated by a single space.
To get this expression to catch names with 3 or more (or even 1) parts, you can use grouping. The expression ^\w+(\b\s\w+)*$, which will look for 0 or more instances of words following the first. This will allow your form to take all kinds of names, while still ensuring that only single spaces occur between the various parts of the name.
- Josh Carlson
Kendall County GIS
DeonLengton
Hi Sunita
You can use a regex expression in the constraint column to check for this:
regex(${<fieldname>}, "[ ]{2,}")=false()
Then add a message in the constraint_message column to notify the user.
Hope that helps
Kristofer
New Contributor III
Hi DeonLengton,
Thank you very Much. This is Working Fine.
Regards,
Sunita
