validate column in survery123
1300
08-27-2018 09:45 AM
Pa_Lotus
I have two textboxes in survey123
when number 100 is filled in first textbox
second textbox should auto populate with value "true", other then 100 the value is " false"
Thanks
BrandonArmstrong
Hi Malla,
Take a look at the following documentation
Formulas—Survey123 for ArcGIS | ArcGIS
I'm thinking you'll want to setup a calculation like this in the calculation column of your evaluation question.
 if(${value}='100','True','False')
I have also attached an example XLSForm
BrandonArmstrong
Hi Malla,
