Using mode=copy with Field App
1554
10-21-2022 07:46 AM
CoreyLunty1
Hello,
I was wondering if the ability to use the mode URL parameter to open a copy of an existing survey record has been implemented in the field app yet?
In a map authored with Map Viewer, I have polygon features and I am using an attribute expression to find the most recent inspection for each polygon feature, and then concatenate together a URL to try to open survey123 from within Field Maps
Example result:
arcgis-survey123://?itemID=[map item_id here]&mode=copy&globalId=517A2C24-2A78-496E-932C-EB8BA973C707
I have tried using global IDs both with and without the braces enclosing them, but no luck. There are no errors messages, but the survey just opens with no answers prefilled. I am the owner of the survey form and layer.
I am testing using Survey123 on my iPhone. I do not have an Android device to test with, however our field users would be using Android devices.
I would simply use URL parameters to pre-populate answers, but the form uses repeats I would like pre-populated too, so this is not an option.
I'm paging @JamesTedrick  to this thread because he seems to be aware of Survey123 development status.
JenniferAcunto
When using the field app the parameter is action=copy.
Parameters for a field app
- Jen
JenniferAcunto
- Jen
CoreyLunty1
Thank you for your quick reply! I should have read more carefully.
I change 'mode' to 'action' and upon clicking the URL, the app now opens the inbox when I click the hyperlink. Am I correct in assuming then that I need to have the inbox enabled for that survey, and that the survey response globalId I reference needs to correspond with a record matching the where clause of the inbox?
JenniferAcunto
I usually work with browser based surveys, but i do believe the survey response you are trying to copy needs to be in the Inbox to launch it. I have added  &update=true to the URL before to refresh the inbox to ensure the correct survey response is relevant. If you have a filter set up on the inbox, the survey would probably need to match that filter to work.
- Jen
