Using jr:choice-name() in the Instance_Name setting
9523
12
05-04-2021 05:37 PM
GFernando
I love using jr:choice-name() to return labels associated to select_one and select_multiple question. But I haven't been able to use it in the Instance_Name setting. It throws an invalid error.
I've only tested this on a windows 10 PC with the latest Survey123 field app.
TrishaSchlake
Yes, this is the correct enhancement number.
MichelleWilliamsERM
Good catch,
I love how @IsmaelChivite's brain works because this is a clever hack.
The only change I would make is Do Not set the esriFieldType to null if you want to see the data in your instance_name expression. Because you need the answer in Survey123 so it can pull that data.
Have a spatial day, keep plugging away!
EthanLambert
Hello, I wanted to 2nd the request for this enhancement.
I have a multi-stage process in Survey123 & use the instance name settings to make the inbox readable. The titles would be even more clear if jr:choice-name were supported for instance_name.
