Using Caplock with mask in Survey123 how can we have spaces between words?
5161
11
03-21-2018 07:52 AM
DiegoLlamas
I have been doing some test with caplock for my text fields in survey123. I was able to do it.
In Esri:inputMask y add this symbol > and xxxxxxxxxxx for the quantity of letters we think we will be using
We write with spaces in survey 123
But when we see the info on a map we can see the info but with no spaces between them
If we open the survey we send we see the same behavior. No space between words
I asume it is because in Mask we do not have any space between x but we do not have control what the user is going to write, so, my question is How can we have caplock for words and respect the space we put on them? is it possible?
>PLEASESAYYES
Thanks for your help!
Diego Llamas
LAM123
Thank you for this, the function seems to load fine but when I try to test the function in the Survey123 connect form (unpublished), nothing happens, and the text remains uncapitalised?
LMedeirosUI
@LAM123 Did you test it in the script testing area of S123 Connect?
If it works there, then you'll need another field to output the calculate results to. The calculate function won't update the field it used to obtain information, it needs somewhere to output it to. See attached screenshots, zipped script, and XLS form.
