Using a Locator View in Survey 123 Geopoint Question
1821
04-29-2024 07:40 AM
HenriettaK
Hi Community,
I am working on a survey with a geopoint question that will be publicly available for customers to enter their address and search for internet options available. I would like for customers to only see address options in our area of Texas when they begin typing their address, as we want to make sure they are not confused by potential address options in other states. I have two questions about this workflow:
1. Is a locator view now supported for publicly shared surveys?
2. I have set up a locator view for testing that seems to be working with the survey shared to our organization. However, I only want the locator view to be visible and not the ArcGIS World Geocoding Service. Is there a way to do this only for this survey without deleting the ArcGIS World Geocoding Service all together? This is how it currently looks:
Please let me know if there is a way to only show the locator view in a publicly-shared survey!
Any help is very much appreciated!
leahmaps
IN the bind::esri:parameters field do "geocode={IDofgeocoder} the ID of the geocoder can be found on the information page on arcgis online.
This article might help you more if that doesn't work >
leahmaps
Here is how you can do that. Uncheck *use all contents below" and just choose the one you want.
HenriettaK
Hi Leah,
Thank you so much for your response! I don't think I have this option since the survey was created in Survey 123 Connect (sorry, I totally should have mentioned that in the original post!) Do you know of a way to do this in Survey 123 Connect?
Thanks so much!
leahmaps
