Use Name as Column Headers in Data
806
08-08-2025 04:13 PM
CascadeDiver
Is there a way to ensure that Column Headers use Names instead or Labels for the data? I have fields that utilize the same labels. This does not work well looking at the Data.
AlfredBaldenweck
MVP Frequent Contributor
You can set the field alias manually using the bind::esri::FieldAlias Column, otherwise it will use the label in most cases
https://doc.arcgis.com/en/survey123/desktop/create-surveys/esricustomcolumns.htm#:~:text=2%2C147%2C4...
AlfredBaldenweck
CascadeDiver
Fantastic. Thank you!
