URL Web form
2181
11-02-2020 06:53 AM
OussamaMerhi
Am using the below syntax to open a survey123 web form:
https://survey123.arcgis.com/share/8e6e711ef9db4c248f2528169f360191?mode=edit&globalId={globalid}
The above URL is correct but The system is stuck once try to upload data. The reason behind this that it contains in the repeat table 22 records. Is there a way to avoid this.
Ruth_JiatengXu
Hi Oussama,
Thanks for sharing. Is there any repeat inside repeat (nested repeat) in your survey? If yes, then the reason for the failure is that the edit mode does not support nested repeat at this time yet.
If there is no nested repeat in your survey, and you still see the submission error, could you please share your XLSform with us? so that, we can help you identify the cause of the issue.
Ruth
OussamaMerhi
Actually there is no nested repeat. It doesnt give me submission error . Ist is just freezing because the number of records in the repeat is big.
