Uploading data from files into survey
898
07-12-2023 09:04 PM
AnnetteL
I am a new user of Survey123.  And Survey123 connect.
I want to know if the following is possible and the best way to do it.
I want my survey to take a landowner's unique number among 100's of landowners and go and look in a file/database and upload the tree species and number of trees allocated to that specific landowner and for them then to the record in the table the number of species that are currently alive.
Is this possible and if so how is the best way to do this?.
ZacharySutherby
Hello @AnnetteL
I would suggest checking out the pulldata() function. You can store all this information in a CSV file and when the user enters their unique number you can populate information from the CSV for the record that matches the unique number.
Please see the Use existing data in your survey - the pulldata() function Esri Community blog for information to help get started. Please also see the Retrieve a value from CSV documentation for more information.
Thank you,
Zach
