Upload Shapefile or Feature Class into Geoshape question
1029
10-14-2022 10:17 AM
dnykodym
We're creating a survey for outside contractors to provide polygons for proposed work areas. Some of the contractors have existing shapefiles, feature classes, and kml's that they would typically send to us as attachments but we want to move away from that process and use Survey123. Instead of having them redraw a polygon in a geoshape question, is there a way they can upload the pre-existing polygon into the geoshape question so they don't have to draw the feature again?
IsmaelChivite
Esri Notable Contributor
Hi. It is not possible to populate a geoshape question in a form through a shapefile or KML upload. Sorry.
You could certainly append shapefiles to the survey layer, but not 'draw' the geoshape by uploading a file into the form.
