Upload data in Survey123
1914
05-02-2023 05:16 AM
RaghavGupta
Is there a way we can give option to upload Shapefile, Json data, GDB, Zipfile in survey123 forms.
IsmaelChivite
Esri Notable Contributor
If using the Survey123 web designer, add a File Upload question type
If using Survey123 Connect, use the file question type. More details about the XLSForm syntax here.
It will be the responsibility of the respondent to zip the shapefile and all complementary files before uploading.
IsmaelChivite
