upgrade to Connect 3.18 breaks javascript function Position(..)
1186
10-24-2023 08:24 PM
AKitch
Hi
I've just upgraded my Survey123 Connect app from 3.15 to 3.18. In doing so a lot of my Javascript functions sourcing repeat variables and the position are not working. It seems now the Position(..) function is passing an object instead of a number. I tested by passing the position directly back to a text field and get "[object Object]". The function I used was simply:
function getPosition(pos){ return pos; }
referenced by:
pulldata("@javascript", "survey_func.js", "getPosition", ${shot_repeat}, position(..))
Is there a new way of using Position(..) in Connect 3.18? I'm only building mobile surveys so not worried about web forms.
Cheers
AKitch
Looks like this problem has arisen due to bad column/grid specifications in the apperance column of the XLSForm.
AKitch
