Update question results based on if a group is expanded or collapsed
1704
11-17-2020 08:42 AM
Andrew-Bowne
I have a survey which is being used to conduct inspections.  The survey has several groups (i.e. Electrical, Plumbing, HVAC).  Inside each group there are several questions that are all answered "YES-NO-N/A".  I would like to have all the groups start off collapsed and the answers within that group all be defaulted to "N/A".  If a group is expanded, I would like all the questions within that group to have no answer which would require input from the end user.   Is this possible?  I have not seen any documentation that shows how to update a question based on the state of a group (expanded or collapsed)
Thank you!
by Anonymous User
Not applicable
Hi Andrew,
This is not currently possible. There is no way to change the defaults or values of questions inside a group based on the status of the group (expanded/collapsed).
Regards,
Phil.
by Anonymous User
Not applicable
Hi Andrew,
Regards,
Phil.
Andrew-Bowne
Thanks for the confirmation, Phil.   Is this something that might be considered for a future release?
by Anonymous User
Not applicable
Hi Andrew,
No, it is not currently on our roadmap. If you want to see this feature in a future release, I suggest raising an enhancement with Esri Support and also create an ArcGIS Idea. This helps track the demand and gather additional information on the workflow.
Regards,
Phil.
