Update a calculation (pulldata in a repeat) while the survey is being filled
879
05-16-2023 04:35 AM
RaynerCastro
Hello!
I have a survey of transport stops. In this, each stop made is recorded in a repeat group (they can be more or less depending on the demand and bus capacity). By default, it is designed to mark the final destination if there is no more stop and indicate the estimated distance from a csv (pulldata).
When a new stop is added, it should mark the estimated new distance also indicated in a table. But you have to update manually.
Is there a way to update automatically? the data comes from a pulldata function (csv)
Thanks!
Tags (3)
