See attached xlsx form.
When I add 1 to a field set to type integer I get the expected result of 1 more than the integer value
e.g: 1 + ${int}....if int = 2 the result is 3
However if I change the integer field to calculate or hidden and 1 to the value of the field I get an unexpected result of a the calculate or hidden value with a leading 1. In this case I also have the field type set to Integer
e.g: 1 + ${calc}....if calc = 2 the result is 12
Am I doing something wrong here or is this a bug?
Hi Brent,
Calculate questions are text by default, causing the 'addition' to being string concatenation (i.e., 'a' + 1 = 'a1'). You would either need to convert the value using either int() or number() functions, or create a bind::type column in you worksheet and specify either integer or decimal as the type of the calculate question.
Hi Brent,
Thanks James, The int() function worked great. The bind::type set to integer alone did not make a difference.
