mulitple image fields with relevant rule
1031
11-22-2017 09:02 AM
Lake_Worth_BeachAdmin
I would like to have multiple image fields however I only want to show 1 image field at a time. if the a user takes a picture with img1 field, then img2 appears and if img2 picture is taken then img3 appears, etc.. How can this be done with the relevant field?
JamesTedrick
Esri Esteemed Contributor
Hi Joe,
You can have an image field show after a previous image is taken by using the relevant statement ${image_question} != ""
worked like a charm thank you
