I have a survey published via Survey123 Connect, which contains several select_one questions. The questions are required and have no default answer/value set. When a user saves an incomplete survey to drafts and reopens the draft at a later stage, the survey is as is. The answered questions are unchanged as expected, and the unanswered questions are still blank.
The problem arises when the survey is saved as a draft a second time. When the user reopens the survey, the answered questions are still fine, but the unanswered select_one questions now default to "No". This is a challenge as "No" is still a valid answer and users are no longer certain where they stopped their capture.
Is there a work around to prevent this from happening?
Environment:
- Published from ArcGIS Survey123 Connect 3.11.123
- ArcGIS Survey123 mobile app Android Version 3.12.277
- Attached sample survey
