Unable to load Design Tab on Survey123 Website
5197
29
06-09-2017 06:31 AM
RobertMarros
Is anyone else having an issue opening up the DESIGN tab on the Survey123 Website? I am trying to open up an already published survey in order to update some of the answers to a question. However, when I click on the DESIGN tab, I get those three fluctuating bar graphs. I have already gone through and cleared out my cache so I am not sure what else could be the error.
ZachMueting
Can I do a save as or would I need to start from scratch?
JamesTedrick
Esri Esteemed Contributor
Just to make sure, your last comment talked about the 1019 issue, which so far we've only seen with surveys authored in Survvey123 Connect.  The website uses the term 'Save As' to create a new survey from an existing survey; Survey123 Connect uses the term 'Create a new survey...' to do the same.  Is the 1019 error occurring with a survey you authored on the web?
ZachMueting
No, the survey with the code 1019 issue is a Survey123 Connect survey.  I'm creating new right now and trying to shorten name cells and eliminate any non-letter text (inlcuding underscores).  There are also now no capital letters.  About to publish and see what happens!
Vanessa
ZachMueting
So I just republished and it worked well the first time and sent but when I tried to edit it and resend I got the same code 1019 error.
Vanessa
ZachMueting
I'm thinking my survey send problems (code 1019) might be because of what I'm trying to survey.  I designed a repeat question to identify the park being surveyed and then a group of questions to collect details about the selected park.  Inside the group of questions I have repeat questions.  It is currently not collecting separate details for the separate parks selected and is staying with the same data collected for the first park surveyed.
JamesTedrick
Hi Vanessa,
Yes, what you described certainly is likely the case- we do not support nested (multiple levels) of repeats.  We support any number of repeats to the parent form, but not a repeat inside a repeat.
ZachMueting
So I took out the nested repeat, republished it and it worked fine....the first time...when I try to edit and resend I get the same 1019 error .  My guy is out in the field right now and I'm not sure what to do.  I also refreshed the inbox and the only information that came through were non-repeat questions.  I'm thinking there's something related to the repeat questions that's buggin out when being submitted.  Should I try getting rid of all repeat questions?
JamesTedrick
Can you share the XLS file with me?  jtedrick @ Esri.com
ZachMueting
absolutely? how do I do that?
ZachMueting
oh, sorry...I thought that was your twitter tag...the spaces threw me...I'll email now!
