Translation Assistant option is not available
221
08-05-2025 04:50 AM
Kristofer
Hi Team,
Translation Assistant option is not available under the Survey123 Assistant – Extensions tab.
As mentioned in the documentation Link, I have already enabled the "Allow use of AI assistants by members of your organization" setting under Organization > Settings.
A snapshot is attached below for your reference
Could you please help me to solve this issue.
Thanks & Regards,
Kristofer
Leena_Abdulqader
Hi @Kristofer , I believe the link is out of date. It says at the top this is the recent one https://community.esri.com/t5/arcgis-survey123-blog/survey123-analysis-tools-beta/ba-p/1629126
The assistant now includes the translation https://doc.arcgis.com/en/survey123/get-started/survey123assistant.htm
Hope that helps!
