Time format feature reports
1159
12-05-2024 08:06 AM
ChrisHertel
Hello, my feature reports keep showing time in 24 hour format.  I am trying to show time in a 12 hour format.  Currently, using ${time | format: “h:m”}.  This passes the syntax check, but I cannot generate a report without getting an error.
ChrisHertel
Error reads failed to parse since format not supported by current field.
RClavero
Hello @ChrisHertel, have you tried using ${datetime ? See below an example:
${datetime | format:"h:mm"}
You might also want to check this previous Esri Community post.
ChrisHertel
Unfortunately that does not work.  My field name is time, not datetime.
