Survey 123 pulldata expression: concatenate 2 string attribute fields
1003
12-06-2024 03:04 PM
SueBoelk1
I am new with XLSForms and with writing expressions in the calculate column.
Question:
How do I format a pulldata expression to retrieve 2 attributes from 1 feature and concatenate them?
Ex: I have a layer with specific professional title attributes: "Dr. of Economics" in one attribute column.
The name of the person: "John Jones" is in the other attribute column.
I want to concatenate the title with their name "John Jones" to result in and display the name in the
Requestor field in my survey form: It should read: Dr. of Economics John Jones.
Thanks for our help.
DougBrowning
MVP Esteemed Contributor
You have to set up 3 fields total.  1 for each pulldata and 1 for the concatenate.  You can set the bind::esri:fieldType column to null if you do not want these temp fields in the service.
SueBoelk1
Thank you, Doug I will work on this and do more research on the process.
I have an idea of the direction that I am going now.
Go Pack!
