There are any way to filter the results in the Map search box?
1074
07-10-2020 03:00 PM
LMBaptista
Hello everybody.
When I use a map in the survey123, there is a search box to find locations.
There are anyway to prioritize the results from a country or from the area visible in the map?
It's not "user friendly" being in UK and get results from USA or being in Portugal and get results from Brazil (like this: http://prntscr.com/tfmhou  )
Any suggestion?
Thanks in advance.
IsmaelChivite
Esri Notable Contributor
Hi. One option you have is to configure the locator of your ArcGIS Organization with a locator view, limiting the search to the UK.  In this way, not only Survey123 users, but also any apps you may have in your organization will benefit from the filter.
More info on locator views at: https://www.esri.com/arcgis-blog/products/analytics/analytics/customize-your-geocoding-experience-wi...
IsmaelChivite
LMBaptista
Thank you.
It worked out great.
Best regards 😉
