The mode=edit&globalID parameter in Survey123 does not work.
768
06-23-2025 07:18 AM
Davide_Pili
I'm working with a public survey. I created a Make flow that generates an email containing a link to the survey for editing a record. The generated URL works if I'm logged into AGOL, but it doesn't work if I'm not logged in. The feature layer is public, the app is public, and editing is enabled. The URL is the following:
https://survey123.arcgis.com/share/<survey-id>?mode=edit&globalId=%7B0034070E-A04F-4B76-8132-D530456...
Neal_t_k
MVP Regular Contributor
Just a shot here: who do you have the results shared with,  the form is public but did you share results?
MobiusSnake
Does your view have a filter on it?  I tried querying the Global ID in your parameter and it returned zero results, however when I queried the source feature layer it returned the feature as expected.
Davide_Pili
It has no filter. If I open it in the browser session where I'm logged in, it returns the data. If I open it in another browser session where I'm not logged in, it doesn't return any data.
Neal_t_k
Davide_Pili
Thank you. I had only shared the Feature Layer with Everyone, but not the view that ArcGIS Survey123 created. Now it works.
