Thank you Survey123 Team
1667
07-18-2016 11:23 PM
ecrdaecrda
Thank you Ismael and the whole Team of Survey123 , you have no idea how you have helped us with this application , The only few things I can suggest that may be will  be added in the next release are:
1. Send notification(Triggers) Where the admin can select the fields to be emailed to number of people. e.g. When a field worker collect information in this region/districts it automatically send a notification the person responsible for that region/districts .
2. To be able to load excel sheet with co-ordinates or shapefile ,e.g. when a field worker goes to an already mapped or collected feature ,it allows the field worker to update the existing meter reading and later on the admin can be able to see when last a field worker visited this meter and what was the reading at that time and be able record the current reading
3. Routing , where a new field worker can be able to drive to the collected feature
Thank you all
GaryBowles1
For send notifications, we are using GeoEvent to poll the feature service and send an email. You can easily set-up filters to send email to various people based upon location of survey, certain data collected, etc. If you have GeoEvent it works very well.
You can use Navigator to drive to and from the collected feature and open Survey123 directly from Navigator.
Check out Apps for Everyone | Field and see how Survey123, Navigator, Workforce and Collector can all work together.
--gary
