Surveys from Survey123 Connect can't be seen in a web browser
2458
06-23-2017 03:32 PM
AliciaPerez
Hi!
When I publish a survey from Survey123 Connect, I make it public and want to see it in a web browser (chrome), I get this message error: Surveys published using Survey123 Connect for ArcGIS are currently not supported. Any ideas why this is happening? I did this workflow a while ago and worked just fine.
JamesTedrick
Esri Esteemed Contributor
Hi Alicia,
Surveys published from Survey123 Connect are not supported by the current web form page.  We are working on a new web form that can handle the complexity that a Survey123 form can have- you can access it via Survey123 Connect; with the form preview open, click on the globe button and select 'Open in web app'.
by Anonymous User
Not applicable
I am also having this issue. Create Survey in Connect, published fine and was able to complete survey on my phone. When going to open the survey from connect using the cloud - none of three options work. Keep get the error The survey does not exist or is not accessible.
Any ideas?
