Survey123 Web with Enterprise portal
610
08-25-2025 06:34 AM
vijaybadugu
We have been using https://survey123.arcgis.com/portalUrl =<Enterprise Portal>. sometimes, it does not open and throws survey not found error on the web browser. to avoid this, can we use windows survey123 app to open from another application through web link?
CodyPatterson
MVP Regular Contributor
Hey @vijaybadugu
Normally, it doesn't work due to a problem connecting to the Portal itself, that being said, I'm not sure that using the app would change much since I assume they're on the almost same connection. I'd definitely be interested to hear the results if you give it a shot though!
Cody
kntr
Hi @vijaybadugu,
Could you try going to your portal organization settings > Security. Then, add Survey123 as an approved app in your portal?
https://enterprise.arcgis.com/en/portal/latest/administer/windows/manage-app-launcher.htm#ESRI_SECTI...
If this answer solved your question, please mark it as "Accept as Solution" to help others who have the same question.
Cheers,
kntr
