SURVEY123 (using survey123 connect) Errors with EsriGlobalID
1042
11-28-2017 06:10 AM
SHANNONDWYER
SURVEY123 (using survey123 connect).... I'm getting errors for the EsriGlobalID, can anyone help with this error (Attached in a screenshot)?
I have found little documentation on errors like this. I am currently unable to publish my survey to collect data, dropping this field works for the survey portion. As this is a class assignment the lack of an EsriGlobalID will mean a reduction in the overall grade received. I have asked my professor as well, and he does not quite have a solution, he has suggested that I start over using Survey123 and avoid connect. I am convinced that there is a way to solve this issue and would prefer to learn from my mistakes, and maybe help others who receive the same error message.
At this point, I have made the survey publically accessible for data input and analysis so that I can get some direction from members of the ESRI community
Thank you,
Shannon Dwyer
Fleming College GIS and Cartography
JamesTedrick
Esri Esteemed Contributor
Hi Shannon,
This is due to line number 3 in your form.  Survey123 will create a globalid field automatically if you are not using an existing feature service.  It looks like you are trying to create a globalid field manually; while you've set up the question type correctly with the bind::esri:fieldType of GUID, you gave the question a default value of 'esriFieldTypeSingle' (this looks to have occurred because some of the field validation seems to have gotten misaligned in your spreadsheet).
SHANNONDWYER
That makes Perfect Sense James,
I have gone ahead added bind::esri:fieldType of GUID and checked my fields for validation and I have also ensured that the default value of 'esriFieldTypeSingle' is NOT USED as you advised.
However, I seem to be having the same issue with the attached excel information (Updated workbook attached)
Should I set the default for this to 'esriFieldTypeSingleGUID'?
Thank you fro taking the time to try and help me with this
Kindest Regards,
Shannon
