Survey123 URL XY center issue with commas, geopoints, geoshapes
816
05-07-2020 01:15 PM
by Anonymous User
Not applicable
I am trying to pass many attributes from a web service to survey form, including spatial data.
1: I want to pass the center point to populate a geopoint location. When I test the URL I configured the center parameter passes as such: &center=35.431279121%2C-86.210751558
But nothing populates in the geopoint question from this.
If I remove (manually) the %2C and replace with a comma, it works fine. Is this a known limitation when using the web form for survey123?
2: I actually would prefer to replace my geopoint question with a geoshape question but I run into several issues:
If there are many vertices the url length is a problem and I get a 494 error.
Passing the vertices can't be a "center" parameter, but is the answer to a field/question instead so I get the following:
field:prescshape=35.4955258942163%20-87.5681752757275%3B35.4950675536209%20-87.5676845847538%3B35.4947421087082%20-87.5669107375285%3B35.4946169958997%20-87.566460080437%3B35.494379472624%20-87.5664859347469
I tried here doing the same manual fix of removing %20 and replace with comma, plus remove %3B and replace with semicolon, but the polygon does not show up in the geoshape question.
A solution to either problem would be great! Or if this is a known limitation of the web form that is ok too.
BrettStokes
Hi Jeff,
Did you end up finding a solution to either of these issues? Please post on the forum if you did.
Brett
by Anonymous User
Not applicable
Hi Brett,
I did not find a solution to either problem, but the point parameter started to pass. I may have had to remove a space in it. I do not know much about how URLs work so I can't really say much else about this issue.
