survey123 submission_url not compatible
802
09-20-2022 11:03 AM
fyang
Hello,
I'm using survey 123 to publish on arcgis portal with existing result feature service. But when I publishing I got the error of "The custom feature service submission_url" is not compatible with this survey.
I used two method to create and confirm the url.
1, I created a new survey with existing feature service (same as I'm using for the target survey) and copy the url created automatically in the spread sheet.
2, double checked the url with suggestion below.
https://community.esri.com/t5/arcgis-survey123-questions/submission-url-compatibility-error/td-p/799...
 But still got the same error. When I remove the url line from the setting, the publishing is fine but it will create a new feature service as survey result.
Any clue? Thanks!
Fan
MichelleWilliamsERM
Good day to you; let me see if I can help.
You said you created a new survey with the existing feature service (same as I'm using for the target survey) and copied the URL created automatically in the spreadsheet.
If you build your Survey123 this way, it links everything together.
I hope that helps!!!
fyang
Yeah, I created the url exactly same way but it gave me the error.
