Survey123 submission_url is not compatible with this survey
634
10-18-2023 11:48 AM
ChristopherMask
Not sure how to fix this.
Not sure if is because I am using a related table or not!
Christopher
IsmaelChivite
Esri Notable Contributor
Hi. You seem to be in the right track. It looks as if the FinanceandAdministration relationship is using a text field instead of a globalId-guid based relationship.
IsmaelChivite
ChristopherMask
Ismael,
Thanks for the direction. Assigned globalid to the features class, created a new guid field in the related table, and Overwrite the web layer. In business, thank you very much.
Quick question, is it possible set a row visible by verifying if a user is an organizational user vs anonymous user?
I would like to use one survey, but show additional fields if the user is part of the organization. Plus, I have been told you can share a survey by not making it public and giving users a (password/id/token) to access it?
Christopher
