Survey123 Sketch / Drawing -> Inbox Broken?
868
10-21-2020 09:27 AM
JordanMiller4
Occasional Contributor III
What can I do to allow sketches to be view in survey123 when someone creates them?
by Anonymous User
Not applicable
Hi Jordan,
Can you please provide more details on your requirement?
Kindly see the following thread which could have the answer for your question
https://community.esri.com/groups/survey123/blog/2017/10/09/smart-skething-in-survey123-stroke-by-st...
If this answer solved your question or if you found it helpful please mark it accordingly to help others who have the same question.
by Anonymous User
Not applicable
Hi Jordan,
Are you using two survey forms? One survey to have users submit a sketch, and then another for users to review it via the Inbox?
There are currently some limitations with pulling down attachments (such as images) into an Inbox. While we can editing existing surveys, and add more attachments, we cannot edit or work with existing attachments.
If you can provide more information on your workflow, ideal outcome and current forms/setup it will greatly assist Rawan, myself and others in providing help.
Cheers,
Chris
