Survey123 Required Asterick Posting Below Question Label
1327
08-22-2023 02:27 PM
JepchumbaKoech
Hi everyone, I'm designing a survey and the asterisk for the required questions keeps posting in a new row, below the text for each question. I'm using an XLS form and I have html formatting throughout the spreadsheet. Has anyone else run into this problem? This issue doesn't show up in Survey123 Connect, but when I go to publish the survey, the asterisk is in a new row.
image of how it looks online:JepchumbaKoech_0-1692739444323.pngJepchumbaKoech_0-1692739444323.png
how it looks in Survey123 Connect:
Thanks in advance!
2 Solutions
abureaux
MVP Frequent Contributor
I find this happens more when you have multiple DIV tags. Maybe it's because you are online that it is acting differently.
The fix I have used in the past is swap the DIV for SPAN tags. May work for you too.
JamesTedrick
Esri Esteemed Contributor
To amplify on @abureaux 's advice:
<div> tags are normally displayed as block content, which means that the content following is placed in a new line after the <div> by default.  Conversely, <span> is an inline content tag, which means that it won't place a new line afterward.  If you still wanted to use a div, having the display: inline style property will change the behavior to the same as <span>.
abureaux
JamesTedrick
