Survey123 Report Syntax Select Multiple Help
758
03-04-2025 06:01 AM
aprhyde11
I'm working on a report template for my survey123 data. I need it show the corresponding answer only if "no" is selected on another question.
If accessible=yes, I need my template to return N/A
If accessible=no, I need my template to return the answer to inlet_outlet
This is what I have been using variations of
${if accessible==”Yes”}N/A${/}
${if accessible==”No”}
${if inlet_outlet | selected:"NA" && inlet_outlet | selected:"Inlet"} && ${inlet_outlet | selected:"Outlet"}Inlet and Outlet ${/}
${if inlet_outlet | selected:"NA"} && ${inlet_outlet | selected:"Inlet"}Inlet ${/}
${if inlet_outlet | selected:"NA"} && ${inlet_outlet | selected:"Outlet"} Outlet ${/}
${if inlet_outlet | selected:"Inlet"} Inlet ${/}
${if inlet_outlet | selected:"Outlet"} Outlet ${/}
${if inlet_outlet  | selected:”NA”} N/A${/}
This is the output I get on my sample reports for when accessible=no and inlet_outlet=Inlet and Outlet
I need the output to only say "Inlet and Outlet". I would also like the check box gone.
Thanks in advance!
AnninaRupe1
If I'm understanding correctly, I would try something like this in the calculation field:
if(selected(${accessible},'No'),"N/A","Inlet and Outlet")
If the accessible question is marked "No," return "N/A," else return "Inlet and Outlet."
