Survey123 Report - PDF conversion not honoring formatting
1265
07-16-2021 10:47 AM
jvarasanz
We are experiencing issues with PDF reports not honoring the template format, particularly in tables where the text inside the cell displays in two lines rather than one.
Everything works fine if we produce the report as a word document and use MS Word to either 'Save as Adobe PDF' directly,  or  Save As... and selecting PDF after naming the file, so not sure what might be the reason behind it.
Please advise.
Ruth_JiatengXu
Hi @jvarasanz
Thanks for sharing here! The issue you encountered might be an known issue: https://doc.arcgis.com/en/survey123/browser/analyze-results/knownissuesanalyzeresults.htm#anchor2
Could you please try embed the fonts you used in your report template? Please see the link above for more instruction on this.
If embedding the font cannot fix the problem, could you please send us the screenshot of your word and your pdf report, so that we can identify the issue?
Ruth
jvarasanz
Thanks Ruth.
Embedding the fonts did the trick, although I'm bit surprised given the fact the we are using Calibri and Calibri Light.
Have a great day!
Javier
Ruth_JiatengXu
Hi @jvarasanz
I'm happy to hear that the issue is solved. This issue relates to the copyright of the Calibri and Calibri Light, these fonts cannot be stored in our server, therefore, they have to be imbedded in the template.
Ruth
