I'm trying to run reports from a custom template, but keep getting errors for every field I reference.
Error occurred when rendering by the report engine. Failed to parse ${2020_Prescribed_Fire_Grant_Application_MASTER.Grants}.
Please advise.
hello, I've also been having this problem, although it solves the situation of the reports, then it creates problems in sending new reports, because it doesn't recognize the layerthanks
Hello! Until today this thread is very helpful. I got the same error, and I figured out that the survey layer name starts with number. What I have done to correct is:
1. I logged in to my dashboard>content>survey form folder
2. Open the feature class (hosted)
3. I change the name of my point layer from "1" to "mobile_monitoring_form"
4. It works!
Thank you very much. You guys save my life!
Thanks for the prompt response Zhifang.
I understand the workflow you are suggesting, but my word document is simply referencing ${Grants}. Please confirm it will be OK replacing it with ${_2020_Prescribed_Fire_Grant_Application_MASTER.Grants}. If that is the case, I'll give it a try.
Also FYI, I'm not using repeats in this survey, and producing the reports directly off Survey123.com, although my step is to generate them through the API.
Thanks again.
Javier
Hi Javier,
Thank you for the detailed information and also sharing the workaround which may help others.
I can reproduce the issue by creating a simple survey whose name starts with a number and also contains a repeat from Survey123 Connect, then try to reference a field in the parent layer by using the survey name inside the repeat section in the report template. So for your question, yes, I can confirm that the issue is caused by the additional underscore in the behind layer name which is not the same as the survey name.
In addition to your workaround above, could you try to simply add an underscore in the main layer name in your original template to see if it works for you? For example, instead of using ${2020_Prescribed_Fire_Grant_Application_MASTER.Grants}, use ${_2020_Prescribed_Fire_Grant_Application_MASTER.Grants} to access the field in the parent layer inside a repeat section.
The report engine is designed for being able to work with a feature service directly (even without a survey), so using the correct layer name should work.
Please let me know if it does not work for you.
Zhifang
Thanks Zhifang.
To answer your question, 2020_Prescribed_Fire_Grant_Application_MASTER is a layer name while only Grants is a field name.
However, I believe the issue is related with the name of the layer itself starting with a number, since, although the actual name in the survey is 2020_Prescribed_Fire_Grant_Application_MASTER, it has been saved in AGOL as _2020_Prescribed_Fire_Grant_Application_MASTER.
As a workaround I've done the following:
At this point I'm able to generate the report without any issues. I can't really wait for this to be resolved, so I'm glad the steps mentioned above have worked so far. I'm not sure about the attachments though, so we'll see. The bad news is that the layer will no longer be connected to the original data source. This is not important in my case, but definitely a minus.
Taking all my feedback above, could you confirm it the fact the the service was created where the name starts with a number might be the origin of the issue. If affirmative, it would be good to either allow it in the future, or make sure Survey123 Connect prevents users from creating reports under this circumstances.
Thanks a lot for getting back with me.
Hi JAVIER VARA SANZ,
Seems the report engine cannot parse the placeholder 2020_Prescribed_Fire_Grant_Application_MASTER.Grants as a valid field name or a field name from a parent layer.
Would you please confirm which is your case regarding the field name in the database?
Currently, the report engine doesn't support field name which contains a preriod (.) in it.
In addition, it will be helpful if it's possible to share the original XLSForm and report template file for us to investigate/confirm the issue.
Signed in members can post, follow updates, and more. New here? Register a free account.
