Survey123 Repeats and Geopoint
5093
22
08-14-2023 06:59 PM
KathyFulton
I have created a survey to capture details about resources available at a particular location. I have basic information (organization, contact, etc) outside of the repeat, then within the repeat I ask for the location (using geopoint) and specific characteristics about that location.
The items within the repeat are shown at the proper location on the resulting map, but the data outside of the repeat is showing at (0,0). Is there a way to not have the data outside of the repeat use the location collected on each of the repeats? The data outside of the repeat doesn't change, so I don't want users to have to re-enter it each time, but it should be located at the same spot as the data within the repeat.
Kathy F
typenamelabel
notegenerated_note_form_title<p style="text-align:start;">Maui Fires 2023 - Logistics Assets and Resources</p>
notegenerated_note_form_submit_textSubmit
notegenerated_note_form_footer<a target='_blank' style='color:#000000;' href='https://www.esri.com/products/survey123'>Powered by ArcGIS Survey123</a>
notegenerated_note_prompt_submitted<p style="text-align:center;"><br></p><p style="text-align:center;"><img alt="Green check icon" src="data&colon;image/svg+xml;base64,PHN2ZyB3aWR0aD0iNjQiIGhlaWdodD0iNjQiIHhtbG5zPSJodHRwOi8vd3d3LnczLm9yZy8yMDAwL3N2ZyI+PGcgZmlsbD0ibm9uZSIgZmlsbC1ydWxlPSJldmVub2RkIj48Y2lyY2xlIGZpbGw9IiMzMTg3MkUiIGN4PSIzMiIgY3k9IjMyIiByPSIzMiIvPjxwYXRoIGZpbGw9IiNGRkYiIGQ9Ik0yMi42NjEgMzAuMjQ2bDUuMTgyIDQuOTg3TDQxLjU1MiAyMiA0NSAyNS40NjEgMjcuNzQ3IDQyIDE5IDMzLjQ5OHoiLz48L2c+PC9zdmc+"></p><p style="text-align:center;"><br></p><p style="text-align:center;"><br></p><p style="text-align:center;"><strong style="font-size:16px;">Thank you.</strong></p><p style="text-align:center;"><strong style="font-size:16px;">Your response was submitted successfully.</strong></p><p style="text-align:center;"><br></p><p style="text-align:center;"><span style="font-size:16px;">Contact <a href="https://www.alanaid.org/contact/" target="_blank">American Logistics Aid Network</a> for information.</p>
noteorganization_and_contact_informOrganization and Contact Information
textorg_nameWhat is the name of your organization?
textorg_urlWhat is your organization's website address?
textorg_pocWho is the point of contact for these resources?
textpoc_emailWhat is the contact's email address?
textpoc_phonePhone Number
begin repeatresourcesurveyAdd your locations and assets (click + to add more locations)
noteasset_resource_information_detaLogistics Resource Details
geopointresource_primary_locationWhat location are you reporting on?
select_multiple list_asset_resource_information_deta_asset_type1asset_type1What type of asset / resource are you offering?
textoffer_type_otherOther
select_one list_asset_resource_information_deta_donation_or_paid_offerdonation_or_paid_offerDonation or Paid Offer
textoffer_paid_otherOther
textresource_descriptionDescription of the resource or capability
end repeat
textadditional_informationAdditional Information
dateTimedate_and_time_submittedDate and Time Submitted
EmilySpeck
Hey Doug,
Still having the issue. I uploaded the CSV file to AGOL as well, still the same issue. I believe its my pulldata expression for the Parent Geopoint. Thank you for your help.
DougBrowning
MVP Esteemed Contributor
Is it getting numbers back?  If you move to a csv hosted then your pulldata needs the URL.  That then assumes you are online at the time of course.
Take a look at this post  https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-pulldata-quot-laye...
AaronPDXPaul
I'm having a similar, if not identical need.
Like others in this thread, the Parent point is at 0,0.
What is strange is that in the Parent point, it captures a Latitude and Longitude.
So, in theory, it seems to capture, but not display the location.
I'm hoping someone can help, and that I'm missing something.
We have service requests at properties, that are defined by Taxlots, that have shapes.
The shape of the taxlot should be the Parent for all the Test Pits (points) that are the Children of the Work Area (shape).
I've almost got this to work using points only.
But the Parent is at (0,0) but has a Lat and Long
In the end, we just want to zoom to the Parent, whether it's a shape or point.
But the children are the only ones in the correct location.
Thanks all,
Aaron
