Survey123 PullData not working fully
2132
07-15-2020 03:43 PM
JENNIFERHIGGS
I have a survey that is using PullData.  It pulls most of the values, but does not work for all of them.  The input value is picked from a select one.  Attached is the csv and the choice list.  One that does not work would be
"METROWIDE Phishing Awareness Education Metrics", most of them do work.  Any help would be appreciated.
by Anonymous User
Not applicable
Hi Jennifer,
I had a quick look at your CSV file, and see it contains many special characters such as - % * : . ( ) ' " etc.
For pulldata @ csv it is recommended not to use any special characters in any of the columns/rows, as this may cause issues with the expression trying to load values from the CSV file. I would suggest removing those special characters and test again.
Regards,
Phil.
JNicoletti
I am having the same problem, but tried removing all my special characters from my data csv. Unfortunately, it still doesn't work.
