Survey123 problem accessing form attachments via inbox
1427
11-09-2024 08:23 AM
jcfernandes
Good afternoon,
In Survey123 I have a field where I add a file as an attachment and then send it to the server. When I go to the inbox and retrieve the forms with an attachment, only the question label appears and you can't see the attachments. The form was created in Connect and is being filled out in Field App. Today I installed the latest versions of Connect and Field App (I tested with the latest versions of these software).
I have an implementation of this type in a large project, I attach a small file as an example (to simplify).
Grateful
João Fernandes
ChristopherCounsell
MVP Frequent Contributor
