Is there a way to pull the user's license type into a Survey123 form?
554
11-08-2024 11:27 AM
DarrenLloyd__DOIT
Is there a way to use the pulldata calculation in the Survey123 Connect form to pull the ArcGIS Online User License Type (Viewer, Creator, Professional, etc.)? I am using the pulldata("@property", 'username') to grab the username. However I cannot find a similar solution for the user license type.
Or maybe there is another function I need to use?
Thanks!
Darren
https://doc.arcgis.com/en/survey123/desktop/create-surveys/prepopulateanswers.htm
abureaux
MVP Frequent Contributor
Not that I am aware of.
ChristopherCounsell
No... You've linked the documentation outlining what you can get.
User licence isn't something I've seen people try to get anywhere. In arcade it looks like you can get privileges, role and licence extension, but not licence. Not that it would work with Survey123, just shows it's not common.
https://developers.arcgis.com/arcade/function-reference/portal_functions/
