Survey123 Point Location
451
07-25-2018 07:27 AM
ShelbyPW1
New Contributor II
I am creating a collector map that works with survey123 to conduct various inspections. I've already used the custom pop up and have this working correctly but I've noticed that when I click on the existing feature in collector, click the link to my survey, and fill out my survey, the point location doesn't actually show up at that existing feature location. It only shows up where the GPS is positioned. Is there a way to change this so that my survey point locations are the same as the feature service that I have selected and am creating the survey off of? Thanks in advance.
Brett Clark
Tags (1)
BrandonArmstrong
Hi Brett,
I believe that the following Blog may provide you with a possible workflow...
https://community.esri.com/groups/survey123/blog/2016/07/30/understanding-survey123s-custom-url-sche...
Hope this helps,
Brandon
