Survey123 no questions are visible???
889
04-04-2025 11:20 AM
AlexP_
Please see the screenshot below. I am using survey123 connect latest version and survey123 web for analyze and data report. How can I turn it on to view for analyze? It is not clear. Please advise. Thank you for your time and support!
DougBrowning
Check the Collaborate tab
LizForbes
I'm having the same issue/getting the same message. Were you able to resolve the problem?
Czapiga_Jason
I ran into this recently.
In the xlsx form, my survey began with a group (begin group) question type and included Null in the bind::esri:fieldType column.  Removed the Null and republished. All the questions now display in the Analyze tab.
