Survey123 Multiple Basemaps
2075
12-21-2021 04:47 AM
AlisonSmall
I have multiple web maps because my project is in a building environment (basement, ground floor, first floor, second floor). The user changes the basemap to the appropriate level (web map) of the building.
When a user completes a survey123 form, and is then published on survey123 to a report, the basemap changes back to the default basemap selected in the 'map' tab on survey123 connect.
Is there a way for the user to change the basemap and almost over-write the default? Or can I remove a default basemap?
DerrickWestoby
Yes, it's possible to display a different basemap (and geometry styles/symbols) in the feature report.
See the feature report syntax here - https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereporttemplates.htm
Example:
${project_extents | drawingInfo:"currentLayer" | mapSettings:"271be24809ea473e9eb7d31579563e85"| size:600:550:0:0}
"currentLayer" means that the symbology set in my feature layer's "Visualization" tab will be used.
The quoted string after mapSettings is the itemID for the web map that I want this geoshape to be rendered with.
Assuming that you have a field with something like ${floor_number}, you could make your feature report use a specific web map to print out all responses on floor 1, a different web map to print all responses on floor 2, etc.
${#repeat_name}${if floor_number='1'}
${sample_geopoint | drawingInfo:"currentLayer" | mapSettings:"itemIDofWebmapWithFloorPlan1"| size:600:550:0:0}
${/}${/repeat_name}
${#repeat_name}${if floor_number='2'}
${sample_geopoint | drawingInfo:"currentLayer" | mapSettings:"itemIDofWebmapWithFloorPlan2"| size:600:550:0:0}
${/}${/repeat_name}
You could also do something like calculate the extents of all geopoints on floor plan 1, pass that on to a geoshape question to calculate the extents, and then render that geoshape with a webmap containing all of your collected points (filtered to floor=1).
Here's a few examples from reports using different parts of what I mentioned above:
by Anonymous User
Not applicable
Hi @AlisonSmall,
Just to confirm, are you wanting to display the basemap that they used when they submitted the survey in the Feature Report? Currently the default basemap is used, but you are wanting to display a different basemap in the feature report if a different once was selected at the time of submission?
Regards,
Phil.
AlisonSmall
Hi @Anonymous User
Yes that's correct. Is this possible?
Thank you,
Alison
DerrickWestoby
Example:
${/}${/repeat_name}
${/}${/repeat_name}
